TURBO200R4
stand up straight and grab the world by the a$$
If you turn off the kill switch, all power is cut, even to the gauges. I agree with the post above and in the operators manual it states to just use the key, not the kill switch. As for the light bulb, as it's under warranty I'd take it back but if that's a pain you can always do a simple test, take the bulb that is good and plug it into the right headlight socket to test if it's the bulb or the system. Sometimes bulbs can lie to you. A simple continuity test may reveal the bulb is okay but when you plug it in the heat will cause a disconnect within the bulb.
Just a thought.
yes the book says to just use the key, not the kill switch.
however i always use the kill switch. my reason for this if you use the key the ign switch takes the first contact load. if you use the kill switch the kill switch takes the first contact load.i would much rather replace a kill switch than an ign switch.(also my understanding is that you can take apart the kill switch and clean it) you are not going to do that with the ign switch.
just my opinion
