Rear Wheel Fitting Question
Mark Dunn
.060 Over
Dallas, TX
2009 R3 standard
Hi all,
I'm having a set of Avon Cobras fitted to my 2009 R3 this coming Friday (12-17). I'm having a dealer do it, but I have a question.
As all Valkyrie owners know (or should know), when you remove the rear wheel of a Valk it is advisable to slightly loosen the four bolts that hold the bevel box to the drive shaft cover / swinging arm, and to torque them up as the last thing you do after replacing the wheel. The reason for this is that, on a Valk at least, it enables the drive shaft splines at the bevel box end to find their 'home' position correctly. If you don't do it serious wear can occur.
Now, I know an R3 isn't a Valk but the drive design is very similar. Does anyone know if the Valk style process is relavent to the R3?
Thanks!
Regards,
Mark Dunn
Mark you do not need to but If I were you I would have the dealer pull the final drive and lube the splines with the honda moly60 lube or after a while she will dry up a screw the splines up. If your dealer does not want to do it then save yourself some money pull the wheel yourself and take it to a car shop to have the tire put on my guy charges me 10 bucks and then before I install it I the pull the rear diff and lube the splines on the shaft. Very few pieces of equipment ever die of over lubrication. Just my two cents worth .
