REAR TIRE/WHEEL Air VALVE Removal?
TD is right when I cahnged my valve stem I installed it rotared 180 and now the disc is not in the way I recommend this to anyone as the stem is a cheap part.
Mine is getting changed with the next tire.....what a PITA! Do the newer bikes have vertical stems? I'm going to check next week at the Cleveland Bike Show.
I don't think it would matter much whether you have a 90 degree stem or not. I think what will matter is you find someone that does not rip you bead sealing are installing the CT. Then they will not need any gobley gook to seal it. Which ever tire place you choose mke sure they push the tire bead down into the center so it does tighten up when its going on. That will give a better chance at not ripping the bead.
idk said:
It can be done. I had it done on mine two tyres ago, i.e. about 50,000 miles ago.
I think that it is time to get someone else to install your tyres.
Ian, quick spelling the word tire the way you do. It's incorrect! The corrects spelling is tiarrs! You've been in this country long enough to know better. :wink: 8)
idk said:
...because I am south of the Mason Dixon Line. :lol:
You must be referring to the original Penn/Calvert commissioned survey and not the more commonly known Civil War version that runs south of you.
Found another dealer (Japanese, Honda/Yamaha etc.) that is willing to put another tire on the bike. Apparently the bone heads that put the tire on in the first place must've damaged the bead. Then when you reseated it, put silicone on it to seal it up. That's where the problem lies . . . it sealed the tire, but also clogged the valve.
I plan to put a new valve on it, turned to the opposite side away from the disc and will probably have to spring for a new Riken cause the bead is probably tore to hell.
I would go back to the Triumph dealer the muffed it up in the first place, but it's not worth having my bike sitting in there shop for a month or so for a tire issue. They are crap and their service is crap.
The new tire changer has done a ton of C/T's on VTX's and the Gold Wings and doesn't see any problems with mounting one on the Rocket.
Now I just have to locate another tire. Lessons we learn because of sorry ass dealers. :x
Thanks TD . . . I just ordered another one from DiscountTires.com for like $85 and change.
Still cheaper than a Metz. Shame I only got about 4K outta the first tire, but I like it so well I'm going with the same tire and size.
I'd rather cut my losses and move on that tie up more money and time for someone that is incompetent working on my bike.
Anyone know what brand and size of the rear wheel tire valve?
8mm or 10mm?
I've found a couple manufacturers . . . just need to know what size.
Thanks!
I can only give you the Triumph part number and because my parts guy treats me so good I can't even tell you the price as mine was free
