Frosty Rider
Turbocharged
- Joined
- Nov 24, 2016
- Messages
- 811
- Location
- Toronto, Ontario, Canada
- Ride
- 2010 R III T, 2020 R 3GT, 2001 HD CVO WideGlide
the Suzuki SV site it useless for this information, but i'm betting any money, that isn't the case here, I'm relating to the R3 as it has dual plugs per Cylinder,
Friend has an SV 650 the engine was swapped
- the engine originally had dual plugs per cylinder and two coil packs, 1 for each cylinder
- engine going in has one plug per cylinder
- the wiring harness on the bike is setup for dual plugs
The theory
- I would think it wouldn't matter, as in one signal is being sent to the coil, and the coil is sending the same charge to both plugs at once on the one cylinder, or would I be mistaken and would the coil be sending out a charge to one plug, and then at a given interval it sends another charge to the 2nd plug in the cylinder?
- also would the ECU have to be reflashed for a one plug per cylinder scenario, as opposed to the two plug per cylinder that it is currently setup for, (I would think not, but hey if I knew the answer I would be posting this)
The theory
