Torpedo
.040 Over
- Joined
- Oct 15, 2012
- Messages
- 60
Hey guys. I'm getting ready to put the front cover on after upgrading the clutch springs. I have a couple questions.
1. I can set the preload at 1/4 turn or 1/2 to 3/4. Depending on lifter rod placement. Does it matter which? I don't want to preload the spring too much.
2. Should I hook the clutch cable to the arm/cover before installing it on the block?
3. Once in place, what's the best way to adjust the clutch cable (in a step by step fashion). I loosened the nuts that hold the clutch cable to the bracket that mounts on the front cover.
4. Lifter rod goes behind mushroom head on clutch rod? (pulls center clutch rod fwd with actuation) I'm 99% that's the case.
It's my first time doing it and I don't want to muck it up. Please be patient. I've got the rest down.
