None are correct, all the PC-V maps provided on their website are trash.
My suggestion: Take the base map linked below:
https://drive.google.com/open?id=0ByAqGQEtnUs_MDA1Nm81eTdYLVU
It is not compatible with your Touring, BUT, you can copy the tables, F/L/I, over to your working TuneECU base tune for your Touring. THen download it into your bike. Take your Autotune config in the Power Commander software, and change the enrichment and enleanment values from 20/20 to 12 enrich and 10 enlean.
Go ride a 100 miles, including some full throttle runs through 3rd gear from low RPM to redline, part throttle cruise, 60 and 80 or so throttle acceleration, climb hills, go down hills, creep at 1250 RPM in 1st and 2nd gear, etc come back, accept all trims once and that is now your base PC-V map.  Then DON'T MESS WITH IT.  Repeatedly accepting all trims leads to an overly lean state under 20% throttle using PC-V on Rocket 3s if the L table is still in use.  The leaner it gets, the less power it makes, the less power it makes the more vacuum you pull opening the throttle further, the further you open it and get more vacuum the more fuel is dumped, the more fuel is dumped the more the PC-V+AT will lean it out, its a vicious cycle. Your tuner probably doesn't know about the L table, and is expecting it to behave as a straight up alpha-N fueling system, thus it will just keep getting leaner and leaner until it runs like ass.
Once your base map, the first "accept autotune trims", is established, tweak the enrichment/enleanment to 12/6 instead of 12/10 and let it do its thing forever going forward.
