moklodge
.040 Over
- Joined
- Oct 5, 2009
- Messages
- 91
Here's my setup:
2009 R3 Classic
Tors
Catbox delete
Triumph factory tune for above
K&N underseat filter
GiPro w/ ATRE
After changing the tune from stock to tors/delete, the gipro no longer has the impact it did with stock. Dougl will attest that this is due to the factory map for tors and delete closes the secondaries the same in 4th and 5th as it does in all others gears. So I plan to remove the secondaries. Here's the question - will a 12 minute tune do the trick afterwards? I will not go Tuneboy or TuneECU as they are "over my head". The only option I'm willing to consider is a power commander 5 but I have no local shops anywhere near me (CT) to help if I screw up and I am no mechanic, that's for sure. So I am really hoping the 12 minute tune will compensate for the new found air coming in. Was hoping somebody might know before I do the job.
Thank you in advance for any help.
2009 R3 Classic
Tors
Catbox delete
GiPro w/ ATRE
