petrol tank range
hogweed
Warminster Wilts .UK
Triumph Rocket III 2004
Twice now i've been testing how far I can go on a tank of petrol trying not to run out of course,both time the low fuel light comes on about 110 miles and i've gone up to 160 miles on the trip meter before refilling,
(one ride was two up,the other was solo hammering it down duel carriage ways)
Both times I got approx 17 litres in till full , I had about 6 litres approx left in the tank so this tells me I should get over 200 miles approx before running out,hope this may be of interest to someone ,cheers.
I've just taken mine to 187 miles and it took 20.4 litres to fill, so looks like 200 should be no problem if you are easy with the right hand
we've gone through this before & truthfully, I'm confused BUT I will tell you that I KNOW I get more than 200 miles on a full tank. My fuel light used to come on at 147-150 before the infamous "upgrade" kit which supposedly replaces the fuel thingie, so now if I fill the tank, light comes on between 162-175 ish.... I judge by how much I can fill it the next time.. usually when I think I'm running really low, I fill up & realize I still had a little more than a gallon in there still.. so.. but I did run out of gas once..that sucked...
thanks for that ,my fuel light comes on at 110 miles so I needed to work it out myself,cheers my dear.
210 miles ..... started spluttering (was carrying fuel in pannier), but service station was about 50 metres away downhill. I got the dealer to try the fuel sender fix described on here. Light comes on between 140 and 160miles which I can live with, but would have liked it 170-180 as it;'s very bright and distracting once it does come on.
Mike
I wish I could test my bike in a relatively stable area without all the variables I seem to encounter. My run to Seattle goes over 7 mountain passes or hills over 2500 feet in vertical climb. I live in an area where the wind blows almost constantly (today at 0600 it was blowing at 25 mph steady and gusting to 35 mph). I went for a ride on Saturday of 130 miles one-way. Going down (with the wind) the gauge showed more than 1/4 tank left upon arrival (no light on arrival, but it came on when I went to leave). Coming back into a steady 35 mph headwind, I was almost empty upon arrival - same route, same distance, mostly same speed, same number of stops.
My speeds vary depending on safety factors like wind direction (a 40 mph crosswind gets treated a lot differently than a 40 mph headwind or tailwind), traffic (how many times do I pass the trucks and motorhomes on the two-lane road), and route (unfamiliar backroads verses pounding the slab). Then you can throw in the differences in regional (or national) differences in fuel. Eurogas vs. Canadian vs. U.S. 10% ethanol crap, vs. Oz or Kiwi. Then there are differences in manufacturers of fuel and additives or seasonal differences in the U.S. for the EPA's Clean Air fetishs.
The only thing that makes sense to me is to accurately calibrate fuel in the tank with the gauge (like Mike5100). It seems to me that we can only get meaningful numbers for fuel mileage when we compare one rider to one bike. Just a hundred pounds between riders can mean significant differences in fuel consumption. As much as I'd like to, I'll never get close to MsLizz's numbers as I probably outweigh her by about 200 pounds without the 20 pounds of goatskin I pack on my butt. And one of my boots probably outweighs both of hers (and to put you at ease, MsLizz, I don't weigh 450 pounds).
