Got everything tore down this evening and found both output drive bearings completely wiped out. The innermost bearing substained the worst comming completely appart due to being installed backwards. Yep...you read it right...backwards with the oil control shield blocking off the oil hole in the case, which in turn starved the outtermost bearing. The outer bearing was still intact, but the inner bearing cage which keeps the ball bearings seperated was pretty much gone allowing all the bearings to stack against each other. The end of the shaft also got chewed up a little. PISSED does not even beagin to describe how i feel. Luckily, case damage was minimal. Those bearings must be top secret because there were no identification numbers on them. It will most likely require a total unit replacement. Pictures will be available in my photos unless someone can help me post them on this forum.
