RIII Forever
.040 Over
Italia, Milano
Rocket 3 Roadster MY 16, Street triple 675
Hi everyone today I checked the oil level to my roadster that has 7500 km, I turned it on for 3 minutes and then waited 10 min and checked with upright position. The level marks the min I tried several times even after 3 minutes having turned it off. I wanted to know you when oil ranges between the min and the maximum thank you
Try running it for a minute or so. Then shut her down count to 30 and check it.
Thanks for the answer, I kept the control always at the slightest just just above about half a millimeter....
I'm a bit worried about how much is the gap between min and max
Thanks
a very small amount of oil to fill from minimum to max.
I am probably going to have the piss taken for this, a numpty, newbie question but here goes......if my bike isn't ridden for say a week or more, the oil doesn't show on the dipstick at all. Is this normal? There are no leaks:unsure:
The oil has drained into sump, some leakage I'd normal. Once you start it oil level will return to normal
Yes, thanks anyway, I searched the forum properly and found a thread all about it, I will have to drain some out now I think:banghead:
i am assuming that u have read how to check the oil if not sing out:)
