34K mile 2010 Roadster. Has had the Eastern Beaver headlight relay kit since 6,111 miles.
I'll use yesterday's incident as an excellent example of what I'm dealing with.
Temp's in the low 80's F and the fan comes as I wait to pull up to the gas pump. Bike is running fine and the fan is still running when I turn the bike off. Start the bike and notice the ABS light stays on as I ride off. Bike starts running worse and worse, so I pull over in the shade and turn the bike off. Pull the seat to check for loose connections, fuses, etc. Find no issues. Turn the key on and nothing, no gauges no lights, nothing. Turn it off, wait a few seconds and turn it back on. Lights come on, gauges sweep, etc.. Hit the start button and nothing, not even a click. Check that the headlights are on (they were), hit the start button again and it starts right up and runs great the 20 miles home.
Purposely did not wiggle the bars or ignition key.
Not the first time it's happened and the one constant seems to be the bike being hot enough to require the fan running when I shut it off, even if the bike sits long enough for me to grab lunch. Bike barely runs well enough to move under its own power and sometimes the check engine light comes on too, and the turn signal indicator flashes at warp speed. The check engine light goes off as soon as the bike starts and is running normally. Letting it sit for a few minutes while I check fuses and scratch my ass trying to figure it out seems to be all it needs.
If the fan comes on at a stoplight, etc. and I continue to ride I've had no issues.
When it's running like crap I've tried just riding it for as long as I can stand to, and it doesn't clear up on its own. It has to be shut off, let sit, and restarted.
I've cleaned and tightened all battery and ground connections. When the bike is running normally it runs great. I can run through a tank of gas with no running issues.
Battery is 3 years old and kept on a Battery Tender, has 12.8 volts after sitting overnight not hooked to the Tender. It spins the motor over very well.
Hate to say it, but I'm beginning to suspect the ECM.
Any ideas from the collective?
