No electrics
Thanks! It sounds good and I just added the information to "parts to know about for my Rocket file". I make a point to track/index all the good parts, solutions and fixes I read about here on the forum. I even carry the files on my cell phone for reference.
Why in the hell is that crimping tool $1900.00?
You would have to ask that seller that
But that type of crimper (TH440 - typically sells for under $30) is NOT the correct type of crimp tool for connector terminals - that is an insulated/open barrel crimper.
An un-insulated such as the afore-mentioned Hozan is what is required
e.g. (no affiliation with seller) - HOZAN P-706 Open Barrel Crimper terminals contacts JAPAN NEW
The top jaws are for crimping the conductor, while the bottom is for the insulation/seal
For these Sumitomo Sealed connectors you would use that 'round' shaped one close to the bottom around the rubber seal
Oh.... thanks for explaining. That seller needs to be locked up. I guess some rich but stupid fellow has already bought one of those.
I have a 2008 R3T that has the same problem. Over the last year or so it would sometimes not start, everything is dead. Then out of now where I would gain power again and it wouldn't do it again for several weeks or months. It finally started doing it more often. I traced it down to the main ignition switch harness. I thought at first it was the switch, but discovered it was in the harness. All I had to do was to move the harness and it would come back to life. I opened up the harness and sprayed and crimped the connectors and it seemed to fix it, but now it's back and will not stay on more than 3 or 4 minutes. I didn't notice any overheated terminals last time, but now that I've seen this one I have more to check out. If I see it's the same problem, I may try removing the wire and hard wire it. This forum can be a life saver.
Not sure. I had a 2005 standard and never had an issue. Of course it probably had a little different set-up. I just hope when I do take mine down again I find a problem in the harness that I can see.
@DEcosse do you think this may be an endemic problem for all of us -- just a matter of time ? What to do about it ?
2008 R3T with 50.000 miles same problem
see this is old listing what did u do to solve the problem?
so far I checked wires and looked for something overheating. Found the old owner put in a PIAA Halogen bulb Pulling Way to much Wattage so went to an LED at lower wattage (38w) then the OEM stock bulb but 3000 lumens (bless the mother of light lol) been 3 weeks has not happened again THANK GOD. the last time was getting on a California freeway doing 70 when it went dark.
