new r3 horn question
houkster
Just ordered the horn. Read comments from a couple of those that bought them. Questions: Does the chrome cover still fit back on?
When you trim the plastic piece, is it the entire horn piece you trim or just the front or back? (I'm assuming it's plastic) More description would be appreciated!
I bought one could not get it to fit under the cover hacked away at it and it ended up looking like crap so I went with the small compressor airhorn combo under the left cover, guess you could mount the new r3 horn under there.
I purchased one and had no problem getting it under the cover. I did not have to trim anything either. I just pushed the horn back a little by hand so the cover would clear everything. The bracket is just cheap pop metal and is easily bent in the position you want. Good luck!!!!!
I have the same one that I got from NewR3.com & I had only to trim the front "trumpet opening" bit a little to get the standard cover to fit back on. It also sounds a lot better than the original :D
