im totally inept when it comes to this computer ,cant even get my avatar squared away. but I will walk you thru what I did. using your stock mounting kit .loosen both brackets and if you have used the rubber gaskets ,remove all 4 brackets. slide both brackets, on each leg, all the way up against the triple tree.so both brackets are touching .this will render the stock mounting hole usless and you have to drill a new hole for the top clamp against the triple tree because now the distance between the mounting holes is closer.use the stock lower hole on the bracket . and mount screen bracket with 1 bolt. mark the location of the new hole and take the bracket back off and drill a new mounting hole. put it back together and your done.i put a bolt and a chrome acorn nut to fill the now useless upper mounting hole ,although this is a good spot for some auxiliary lighting.also while your doing this it affords a chance to change the angle of the screen also, buy changing the location of the new top hole.this also leaves a larger gap between the headlights and the screen,but I found the fly in the stock position sent all the wind right in my face .hope this helps
