Info for cruise
Hellfire this is called a tease, Guess you figured it out
Hi Thanks for checking out this thread I am trying to get together a group buy together, just an idea. My thoughts are that I would purchase these and modify the harness for your bike make the custom mounting plate and give you detailed step by step instructions that I developed with pics, like you see here. If that interests you contact me . Thanks Markn2147d
Cost is about $253.85
$74.95 of this is for wireless remote
Model 250-1223 Rostra Ultracruise II
wireless remote 250-1483
Basically there two ground leads (genitive one for remote ,batt)
1. brown accessory wire comes off switch Power when switch is on (if remote there is another accessory coming off the remote harness) positive when key is on.
Red fused 12 positive all the time
Violet tap into brake wire when you step on brake light goes on and ground when off the brake
Grey tap into the ecu wire that's Pink and yellow, square wave vss sensor
How it works (The same as your car if you hit the brake it cuts out the unit, if you pull the clutch it cuts out)
I have been working on this for awhile.
Current stage is that I have set this all up on my Rocket 3 05 and done about a dozen static tests. Seems perfect my fuel tank got scratched last summer at a Dealer and should get it back Tuesday or Wednesday.
Will test out extensively. Thanks
Markn2147d
