Someone that has been inside these forks please help me out - All I want to do is replace the fork seals. Looking at the service manual, is it possible to simply remove the bolt at the bottom of fork (visible when you remove the axle) and lift the cartridge and spring assembly out of the fork in it's entirety without having to disassemble the cartridge and spring? It appears that by doing this you can separate the inner and outer fork and have access to the seals. Highlighted bolt below.
Thanks,
Ted
