This is where I am at now, I completely disconnected the cruise and removed the PCV, Connected Tune ECU no error codes, reset the adaption, let idle for 13 minutes but the green TPS did not come on. So I went through reloading the map and rest the adaption again, let run, still no green TPS light, decided to try on the road, now it starts but won’t run or it will idle rough for a short while then cut out.
When removing the PCV the Crank Position Sensor had to be split then reconnected.But it’s connected up correctly.
Reconnected Tune ECU , no error codes.
Any suggestions.
