While the engine is indeed high, a higher CoG reduces required lean angle, crazy right?
Higher CoG gives you a bigger effective lever on CoG and means it must move a lesser distance for drastic effect.
My hypothesis is that the CoG is MUCH lower than you'd expect from looking at the bike. Front to rear is also not what you'd expect from looking at it.
For my bike, the CoG from front to back is 46" from the rear most point on the bike, on a total vehicle length of 93". That's 31" forward of the rear axle with a wheelbase of 65" (actual measurement), yeilding a 53/47 weight distribution that's actually FORWARD biased. Crazy right?
CoG found using jacks along the foot board rail, I was curious lol.
That all changes with a rider mounted, as the seat is wholly located behind the CoG, so it will shift rearwards significantly. I worked it out mathematically last night, came up with 53.6 Rear / 46.4 front when I’m sitting up in the saddle.
