Lifting a Roadster safely
Hipporider
Hobart, Tasmania, Australia
2005 Rocket 3, 2010 R3R
On my old R3 , there are lugs on the frame under the motor which i made some unequal angle brackets with pins to engage with, providing a stable lifting point for my trolley jack. Owl uses them as well. I have even once forgotten to remove them and were quickly reminded they were there as i cornered. Lol. Does that sound familiar, Owl? ;-)
Upon getting my 2010 Roadster, i was very disappointed to see that Triumph reduced the size of the holes in the lugs. Wtf,why would they do that!
So, I'm left feeling that any pin i weld onto some unequal angle to support the R3R,will bend.
What have other R3R owners done to lift their bike safely with both wheels of the ground like i am accustomed to with my ol faithful R3?
The only solution i can think of is to actually temporarily bolt on the unequal angle when i want to lift the R3R.
I would either drill out the holes a bit, get another set of brackets made up, or mill down the old bracket.
And yes, I remember only too clearly forgetting to take them off after a lift.
Has anyone else gone through 3 sets? ops2:
Drilling out the holes. ..mmm. well, if it leaves enough metal, i guess that would be an easier solution. Not a fan of breaking the seal on the frame's paint job though
Cheers. It's the same principle as the bracket Owl and i use, except that ours are two independent brackets. I can see the the advantage of the single bracket.
One of the guys on a Brit forum I belong to drilled out the holes on his Roadster with no subsequent problems.
I guess as long as you seal the holes with primer & paint you would be OK.
Would be the cheapest option.
Why did they do it?
Obvious. Smaller holes, less weight.
I never bother with pins. Just have a couple of flat bars across the jack so it lifts under the lugs and I haven't lost any of the Rockets yet.
I even had djonly's Rocket on it, and we pulled hard to get the wheel back on as we were in a hurry to get out riding.
That's another option, thank you Erik. I could blend your idea with fastening the plates to the existing R3R lug holes, simply to stop the plate moving, but no load bearing capability
