Hi everyone,
A quick question if I may, I went to adjust the primary TPS in tuneecu and no probs .60 then onto the ISCV nut, I turned the nut in both directions but the voltage didn't change from .69 and I'd like to get to .72 I believe.
I hope I'm turning the correct nut which is at the rear of the Primary stepper and has a little yellow paint on it, is that right? with a little black piece of rubber? ]
Am I doing something wrong? Advice greatly accepted.
If I am turning the correct nut, which direction should I be turning it? up or down as you look at it?
Thanks
Thanks
