Is this the ignition switch issue?
PWGR3
Waurika, Oklahoma
2007 R3 classic
So when i first got my 07 classic in 16, everything worked. Eventually the odo stopped working and found it was a common issue; didn't think much else of it. Eventually the sweep stopped with key on, but would sweep when i tapped the start button. I removed the pc3 and put a tune on it with TuneECU. Now the speedo doesn't work at all, and the tac doesn't sweep until the engine is running.
I've cleaned the speedo sensor and greased all the connections. The idiot light still a works and the tac and other lights work(after engine is actually running) but the speedo doesn't move. I have the p1500 code.
Is this synonymous with the ignition switch issue?
Not a Key-Switch issue
You may have got the P1500 if you had turned ignition on if you had it disconnected
If sensor issue it would be P0500
But this is most likely the not uncommon speedo failure itself
Everything is connected that I'm aware of. Back Lights on gauges come on with key, but the leds and tach doesn't sweep until the engine is running and the speedo does nothing. I'm hoping the speedo didn't decide to take a dump. I can't find any used ones or even new ones on the net and I'm dreading to see their cost at Triumph.
Get a Zumo or other GPS until you find a speedo if you must know your speed.
I honestly didn't even think about gps. Thanks!
It's not that i must know my speed, it's that i have to. Lol i live in a mostly highway area and have a tendancy to speed, so id like to keep my speeding tickets as low as possible, especially with the easy of how quickly these things go 100+ without effort.
