Skippy I don't know how you got those things out of the plugs without breaking the wires off the pins ... must be magic or luck (or both) LOL. 'Cause they ARE held in the casing by little plastic tangs that really should be lifted while the pin is pushed out the back. The red weather-proofing probably could hold them in place if the tang was broken off, but it wasn't supposed to. (I guess it does now
) Hey, if it works, it works huh? Hard to argue with success.
If you look inside the plug closely (us old guys will need some good glasses), you can see the end of the tang. They make a tool just for things like this, but a really tiny eyglass screwdriver or large sewing needle pushed between the plastic tang and the plug pin (from inside the plug, not the wire side) will release the pressure and allow you to push the pin out the back (wire side) of the plug (doing it like this will keep the tang from breaking off and make a click sound when pushing one back in. But I guess it's really only relevent if there is a need to put pins back in them in the future). I'm not too concerned about breaking the tangs, just the wire off the pin.
To clarify the color of the stripe wire, one the bike side (Male) it's the Pink/Black (Violet/Black according to the instructions, Triumph calls it Pink) and the solid black across from it on the sensor side (female). The other striped wire is Black/White ... leave it alone.
For the R3T with three wires ... the solid black wire in the instructions, is replaced by the solid Pink (Violet) on the sensor side (female), and use the Pink/black (Violet/Black) directly across from it on the bike side (Male) as the other one to be relocated.
Older year bikes could very well have different color wires, so the instructions have a couple of quick little tests to do in order to make sure you have chosen the correct wires. It's pretty fool proof.
hehe
Skip I love the bracket ... excellent visibility! No way to miss a shift now eh?
Where on earth do you have the bike parked? With the dirt on it and the company it keeps, she looks parked in the "project" lot. Surely you haven't put her out to pasture have you?
