Rocket Scientist
Grand Exulted Poobah
- Joined
- Sep 27, 2009
- Messages
- 6,837
- Location
- Spring Lake, Michigan
- Ride
- Black 05' Rocket III standard
I would un-hook the battery for a couple minutes. That will reset the adaptives. See if that helps. When I check for vacuum leaks, I use a spray bottle and water. Using a flammable gas will work, but after you've sprayed enough of it, it can be picked up by the intake and cause changes in the speed of engine, thus skewing your results. Learned that from one of my auto mechanic friends. If you rule out a vacuum leak, I would be looking at the cruise control next.
