aviation1972
aviation1972
The 2013 Touring Rocket has its speedo embedded on top of its gas tank. The ignition switch is encased in a steel housing, and there are moldings and plastic fairings along the sides of the gas tank, up at the very front of the topside of the bike. The Roadsters are much more accessible. Speedos are independently mounted, side-by-side with tachs. Ignition switches are mounted independently also. Sitting by themselves. So, if you need to raise a Roadster's gas tank? No problem. Access granted. Well, I own a 2013 Tourer, and I need to raise my gas tank, so I can remove my OEM air intake, and replace it with K&N RU-2780's. I don't want to fool around with my ignition switch, my speedo, or anything else ( Really ). I just want to raise my gas tank, so I can work beneath it. Can someone who has done this before, give me a walkthrough, please? I really need help on this. Thank you so much. I appreciate it.
