R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,382
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
When installing this kit a few years ago on my bike, it occurred to me that the TTS instructions that come with the kit are a bit out-dated, and completely missing the stage 2 bits (intercooler and smaller radiator), hydraulic clutch and supercharger oil circuit installation instructions.
Also, the website etc fails to mention a few “practicalities” that you should know before you buy.
So I documented my install experience with lots of notes, photos & videos with the intention of posting them up as a guide for anyone interested.
So here we are, 3 years later
and with all the TTS question posts lately I figured it’s about time.
Also just a note – my TTS stage 2 is more like a stage 3, since I have internal work already done with the Carpenter 240hp kit. Some photos will show things that the standard TTS kit doesn’t have.
TTS say allow a good day to do the install – I say allow a good month lol.
What you need to know before ordering the kit
Ø You will need to cut up your coil #2 & #3 bracket – for a professional finish, paint or powder coat it after the modification.
Ø You will need to cut up your left hand side handlebar controls, to mate it with the hydraulic clutch lever, master cylinder & reservoir. Best get the modified part powdercoated to give a professional finish.
Ø Following from above, you will also need to modify the OEM clutch lever switch connector to work with the hydraulic clutch lever.
Ø You are directed to remove the MAP sensor, meaning your EMS light will permanently be on, if you use another map besides the TTS TuneBoy one. There are options though, e.g. 2 or 3 bar MAP mod, get Alain to remove MAP DTCs from a TuneECU map, etc
Ø You will need to cut a bracket off the chassis right side spine if you have a Roadster. It’s the one to which the ABS lines fix to for support, behind stock coil #3 position. It needs to be removed to allow coil #3 to move back out of the way of the pipe that crosses over the engine to the intake manifold.
Ø The website ad shows the parts such as engine cover, clutch cover, belt cover, intercooler, radiator and pipework as painted black. However when my package arrived the engine cover, clutch cover, belt cover were bare aluminium. Apparently I “didn’t ask for them to be painted”, but I could pay £100 to get them painted by TTS, plus shipping both ways.
Ø Lead time will be a couple of months, e.g. 3 months in my case.
Ø You will need to order another hydraulic clutch line, if you wish it to follow the same route as the stock clutch cable – the TTS supplied one was too short for the OEM routing, in my experience. Plus you can choose a better colour than silver if doing this.
Ø If going off standard with you kit, e.g. a different size pulley, ask the experienced guys on here – there are a few things to consider/be aware of.
Ø If you have or will install heated grips, you’ll need to drill a new hole in the handlebar as the OEM hole for heated grips cable is covered by the new hydraulic clutch lever handlebar bracket.
Ø Be prepared to have to do some light modification of the TTS parts to make them fit your bike.
Ø LHS front indicator clashes with top of intercooler - so full lock to the left will leave a scrape on top of intercooler. This later resulted in indicator breaking off.
Ø Stage 2 supercharger outlet clashes with footpeg engine bars on 04-09 models at least. You can just about get the silicone pipe onto the SC outlet but it's buckled around the footpeg engine bar.
Ø Intercooler and rad in my experience don't align great, which means part of stock radiator fan housing needs hacking off, also the radiator lower mounts must be bent out to clear the belt and belt cover etc, and bring the rad more into line with the intercooler.
Shopping List/Pre-requisites
Necessary parts
Not necessary but recommended parts
Necessary parts
- 1no. Triumph Rocket III motorcycle
- 1no. garage space equipped for servicing motorcycles
- TTS Supercharger Kit for Rocket III Triumph Rocket 3 | TTS Performance Parts | Rotrex Car & Bike Supercharger Conversions
- T1260107 Engine front (“clutch cover”) cover gasket
- Liquid gasket for engines (high temp RTV silicone)
- Black paint (same black as the chassis) if you have a Roadster
- Crimpable hose ear clamps for vac hoses (7-9mm ear clamps), ear clamp pincers
- 1’ Length of 6 rib V belt
- 7mm Allen bit
- Medium strength “blue” Loctite 243 threadlock (big bottle)
- High strength “green” Loctite 270 threadlock (small bottle)
- Assembly lube
- 1no. oil filter
- 6L oil (spec as per manual)
- 4L coolant (spec as per manual)
- 1no. K&N 62-1340 air filter
- DOT 4 brake & clutch fluid (500ml or more)
- Walbro GSS 342 - 255LPH High Pressure fuel pump
- TuneBoy or TuneECU
- TTS Supercharger "Early" Rockets map (20222 Base)
- TTS Supercharger Roadster map (20355 Base)
- 1no. Pressure plate ball bearing T1170067
- 1no. Pressure plate T1170061
- 1m length of internal Ø4mm silicone vacuum tubing
- 4-way / 3-into-1 Ø4mm barbed connector
- Small bottle of Triumph black chassis paint
- 6no. DPR8EA-9 spark plugs
- T1243510 Throttle body/cylinder head O-ring Ø55.25x2.62mm (3no.)
- 3600160T0301 O-ring water pump to engine front cover
- T3600169 Formed O-ring 2.60mm thick Water pump body seal
- T3550542 Water pump drain bolt crush washer OØ12.5mm IØ6.4mm 0.8mm thick
- T3600910 Water pump to cylinder head O-ring IØ17.86mm 2.62mm thick
- T3550128 Fuel tank banjo crush washer M12 x 1.45mm (2no.)
- T3700062 Plastic bracket for tank prop wand (2no.)
- 925mm long hydraulic clutch cable, with 45° M10 banjo, M10 to 1/8” BSP fitting, colour of your choice 825mm -1200mm Custom Stainless steel braided Powerhose Plus brake lines VENHILL | eBay
- Samco coolant hose kit for Rocket III
- MTC clutch fibers
- 5no. M6x1.0mm 50mm long steel hex socket head bolts
- 5no. stainless steel M6 penny washers (Ø20mm, 1.5mm thick)
- Carpenter Racing clutch springs (5)
- Evans waterless coolant or Engine Ice / Triumph coolant combo
- 1no. camchain tensioning guide T1142048
