Alpha N tuning, TPS/RPM is the most crude method and makes the most assumptions, however, it works reliably with engines that use individual throttle bodies well and with engines that change RPM the extremely quickly, like motorcycles.
Most companies now are using a mix of Speed Density MAP/RPM and Alpha N, which is how the Rocket ECU works. This is why we have F and L tables, the F/L switch is the point at which it transfers from running speed density into running alpha N.
Speed density is better at fueling when there’s a strong and smooth MAP signal, something most ITB motorcycles struggle with, however the Rocket seems to be an exception to the rule for whatever reason.
Almost all cars made these days use a different hybrid method of Speed density combined with MAF fueling, I’m not aware of any bikes that use MAF based tuning.
There was a trend in the late 90s and early 2000s to get away from Speed Density and use one of the other strategies, though, that seems to be now flipping the other direction, and increasingly more companies are offering SD tunes for a variety of cars these days.
