RickyT
2009 Rocket 3 Touring... in Alberta Canada
I have a 2009 Rocket 3 touring I picked up in December. I was readjusting the highway pegs yesterday and couldn't get them even, one leg was bent more than the other when resting my feet on them. No matter the angle or adjustment I made. Then I discovered the right side highway bar was not positioned the same as the left side. The right side is farther back, to the point it is about and 1 1/2' away from the cut out in the rad housing cover. Is This normal?? I inspected the bar itself for damage as a result of being perhaps hit and pushed back but saw no evidence. I thought perhaps I can take it off to inspect further, however, I loosened the bottom two bolts and tried to loosen the top bolt but even with an impact I was unable to get it to budge.
Questions:
-are all right side bars like this?
-suggestions for bolt removal?
-if mine is in fact bent, suggestions on bending back to normal?
-chances of finding a replacement?
I've attached pictures for some clarity
