Well problem solved. It appears that with all my wiring, installing new spark plugs (still had the same problem) that a Map sensor line near the rear of the third cylinder was "compressed" for want of a better word. Dink finally had a chance to look at it, thought it may have been a coil, but they all checked out. Then him and Chris found the "compressed" Map sensor line, got it into a "proper" position and the Rocket runs like new.
I came in at one point and saw them removing the coil "rail" from the looks of it, once you remove it from the frame the coils are pretty easy to get to. Wish I had taken some pictures.
It is great to have a good "pit" crew where you work...I'm going to miss them.
Dennis
