warp9.9
Pocałuj mnie w dupę
You still need to hook up to the ecu to make sure the TPS is in sync with the stepper motor, throttle bodies and the ECU. Heck from it sitting so long you could have a bad spot on the TPS who knows check and verify they are set right in the first place. Do the ISCV reset which includes resetting adaptations and check the throttle body balance. If nothing needs to be adjusted you know its not you problem and your out less then 5 minutes. A little more if you have to adjust her. Check for vac leaks and to make sure the throttle bodies are set down in the rubber intake mounts. All visual checks if they are right I would not be apposed to taking her out for a good thrashing so she knows who is the masterThanks Scott, i just had a big bowl of menudo myselfI will check all the connections and see what happens, it acts like a piece of debri obstructing the fuel or something funny like that
