Here is a shot of the ones on the right side of the bike Lupe the front coil is hard to get at but can be done from under the tank. Since the bike has not been road consistently in a while ( not a lot of good running on her) I would also wonder about the TPS and its setting (not sure if it has a old worn out one or not) but I would hook up to the ECU and check it plus look at the throttle bodies numbers to see if any are varying like you might have a vacuum line dry rotted. Does it have triple filters or did Skip leave hers stock?
anyway here is a shot of number two coil leads number three is right behind number two I would check clean and crimp them a wee bit with some needle nose pliers so they are pretty snug going back on. If you notice anything positive then you should consider looking at the front coil also.
Disregard the SC plumbing so your side coil mounts will not be split into two sections
Hope this helps now it off to get ready for my weekend Menudo soup run
