My '05 Rocket idles great. When I'm accelerating its smooth as can be.
When I ride it to work in the morning (75-80 F) it runs perfect.
Now here's my problem..riding it home from work (15 miles) the temperature is in the high 90s. Halfway home the bike starts to miss out. Its almost like the way my Bonnie acted when it was time to switch to my reserve fuel. Any ideas on this one?
Try checking your fuel tank vent. Sounds like your fuel pump runs out of suction. When the temps get high your tank pressurizes (unless you live in California and you have an evap cannister). That can shut the vent (phffft when you open the cap). If the vent remains shut as fuel is used a vacuum will exist in the tank lowering the suction pressure of the pump. It also can cause hot fuel to flash to vapor in the pump (cavitation). Simple to check, when the bike starts cutting out pull over and pop the fill cap open and see if it's under vacuum (it'll be harder than normal to open it). If that's not it then you haven't spent any money (yet). If it is, buy a new tank cap or clean the one you have.
I took mine out this morning before the mowing incident and it ran perfect in 75 degree temp, yesterday it was 95 and it ran like ****. I think it's the alcohol in the fuel causing the high temp problems with mine.
OK I rode it home..98 degrees outside. 10 miles into the trip it started missing again. This time I pulled over, turned the key off and opened the gas cap. No whooshing sound or anything like a vacuum so I decided to try riding with the cap open for a little bit. It did no good, still sputtered and missed out while riding at a steady speed. I stopped and put the cap back on and rode home cussing the whole way! Grrrr
Just a thought, tomorrow after work, go to a local watering hole and pound a few brewsky's. Wait 'til the weather cools down and then ride home and see what happens.
