Willtill
Nitrous
I tried the grip buster and it was ok for holding the throttle ablout 30% rotation.
The TM (for a lot more money) is good through all of the twist.
Also for those with older (carb) bikes I used to use it to hold a high idle when warming up.
It was easy enough to hold the RPM up 500 RPM as long as you want.
And it's never in the way of grapping a full hand of throttle.
So do you set the tension of the throttle sleeve with the TM first; and then rotate the throttle to the desired setting?
This video shows the guy using TWO hands to adjust it. That's a little difficult and inconvenient (and dangerous) at speed
[video=youtube;0PL6UzLjGe0]http://www.youtube.com/watch?v=0PL6UzLjGe0[/video]
