GiPro /w Timing Retard Eliminator
which tune would you like to compare with the stock touring tune? Is there a Tripp tune you'd like to look at?
I have the PowerTripp Tune (RT3 stock or slip on also called Map20368)..I have been looking at it. I want to compare it to the Latest Rocket Touring Factory Tune that someone has pulled off their stock RT3 before they put on a different tune. I do not have the HansO tweak of the PowerTripp tune.
If you want to give me that tune, I'll create a trim table which shows how much richer (%) the Tripp tune is compare with the stock Touring tune in the F1 (primary fuel) table. The is the percent difference between the Roadster with TORs tune and the Touring stock tune. Basically, above 25% throttle (TP), the Roadster tune is richer.
When I get a cable and get it pulled off, I'll try and send it along. Thanks!
