I can answer that - you won't get an ABS code because the differential between the tires is under 5% the ABS system will allow slightly above 5% without any problems, Lots of guys have run this setup on ABS Rockets without an issue. The 130 diameter will throw a code on an ABS bike because the differential is above 6%. It's not a problem with the 140/75 profile.
