catch up,
had the forks fitted with hyperpro springs,and oil,also fitted progressive 440,s on the rear.
couldent hammer it because of heavy rain,new tyres,galfer pads front and rear.
but what a differance,well worth it.
catch up,
This is good to read. Just fitted a 140/75R17 Michelin Scorcher on front and a Bridgestone Exedra Max 240/55 on the rear. Big improvement in the handling. Have over 700 miles on this set up now and it is even a improvement over the standard size Avon's I had on the bike. Ordered 444's (heavy duty springs) and new springs for the front. Should be here around the first of Aug. Glad to hear a good report about the 444's. Was looking at the Wlibers shocks and had them ordered but canceled the order. The 444's look sharp and had a feeling that they would do just fine.
Metzlers will do better'erish on ice. Stick like warm siht to a blanket. And over on the eastern bit of the atlantic tech 140/75 Metz is a Z rated cover.
Actually there is a way to drain removing the dampner rod bolt that secures it to lower leg. I have drained many forks without a plug by removing it with an impact to assure the rod doesn't spin. Replace copper o-ring and reinstall bolt. Been successfully doing it for 50 years!
Sonny,
I now have a set in perfect condition (444 HD in 12.5 inch).
Only 10k miles on them and always set at the top (softest pre-load).
I have replaced with a set of standard 444.
Sonny,
I now have a set in perfect condition (444 HD in 12.5 inch.
