Forward Controls on 2010-13 R3 ?
IngrahamS
.040 Over
Worldwide
Sold my Rocket need another...
Last time I checked there are little to no options out their for the rocket, I ended up making my own cutting up the stock 06 standard rails but the roadster rails would be the easiest to modify.
-Stew
HOW FAR FORWARD? - Would RAASK stuff do?
[ìmg]http://raask.se/rocket21.jpg[/img]
http://raask.se/rocket-3.htm
Its the other side that is the problem, the ABS rear brake is different and needs modified to fit the old rocket peg set up. It has been covered here before, maybe someone cleverer than me could find you a link.
hi doug not sure about the later ones but i made forward pegs for my 07, used a set of raask rear sets made up stainless brackets to pick up the 3 8mm bolts and the first two crankcase studs above,had to reverse the rear mcyl and make up apropriate linkages for brake and gearchange shouldnt be too hard neebs il post some photos when i learn to use my new phone or you can have a look some time im no that far away in blairgowrie
BigDoug, on the models without ABS would it simply be a matter of cutting the welds and re-positioning the existing controls further forward on the existing rails and adding a longer brake line?
by 10-13 models i assume you own a roadster... if that's the case then you have abs. but yes if your handy enough to cut and weld the controls then you could just move them forward.
