Flasher (and not Rcktnmypkt)
I believe an EP-35 or EP-36 should work
http://www.autozone.com/electrical-...-flasher/novita-turn-signal-flasher/6417_0_0/
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Flasher-Turn-Signal/_/R-NF_EP36_0325389295
edit - the 36 is the heavy-duty version - this one designed for use with trailer or extra lamps; the 35 should be fine -
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Flasher-Turn-Signal/_/R-NF_EP35_0325224932
Has same pin-out config - may not work for LED signals (get a CF13GL-02 if using LEDs)
31 is the Ground, 49 is the Power In (ignition switched), 49a is output to Load (to turn signal switch)
NWMDC
Got one, install with a new Bridgestone this morning and Loctite 65% Moly paste on the splines. What's the torque value on the four bolts where the swing arm meets the bevel box ?
"Align the bevel box by fUlly inserting the wheel
spindle through the bevel box and swinging arm
then, in the order shown below, tighten all the
bevel box nuts to 20 Nm, then to 64 Nm."
The tighten order is basically tighten the nuts in a "X" fashion.
Replaced Flasher. That's not it, now have smoke coming out lense on right front signal housing. Pheck, while working on that I see that I am leaking coolant from the lower hose and yes it's been changed once.
Best deal on line for lower radiator hose ? Bike Bandit ?
That's where I get my OEM parts. You might save a dollar or two getting parts somewhere else but you won't save a bunch. The last order took about a week for them to get it another week before I got it. I've placed orders with them in the past that didn't take that long because they had it in hand instead of ordering from Triumph.
My experience is that BB carries nothing in regard to Triumph parts - they order from Triumph and then re-ship to you - typically takes at least a couple of weeks.
The best price is going to be MADSS or Hermy's
Hermy's has free shipping over $49 order
Honestly though, that's a $17 part - you may as well get from local dealer (unless there is nothing close)
