EXPENSIVE PROBLEM
I WOULD QUESTion the diagnoses.
what code or codes do u have? i can look them up if they are regular codes and not triumph pacific
is the motor running rough?.
vacuum hose problems,sticky linkage,idle control solenoid.
the guys could give a second opinion if wanted?
Glad DEcosse thought it was possible for the throttle body to be the problem and that he doesn't think it is a separate part. Thanks for the info.
p0638 throttle actuator control range/performance
will look at books
I thought it was going to be simple, like a sensor or something. I was amazed that it turned into this, the bike was running fine.
You can see the secondary throttle valve actuator here
Here is the fiche
You can see that the STA is not called out as a separate item
(it's shown as part of the overall assembly #1, but as the part just above the ISCV, it is not called out with its own reference or part number)
So - if that is the failure, then sure, whole TB swap as far as Triumph is concerned.
Again, should not be a problem being Warranty.
Thanks for your help, I do appreciate it and it lets me understand whats happening. I hope its a warranty fix.
it could be the linkage stuck.
the ecu works the 2nd throttle actuator and the 2nd tps reads the position. that being said if either one being bad they could be replaced w/o the throttle body asy. the main tps have gone bad quite a lot of times.
i am not working on it but i guess u will find out.
I think you are right about the linkage sticking but wouldn't it un stick when you give it throttle? Aren't all three hooked together? They say they can not get the parts separately but is there some way to get the parts that they don't normally buy from?
