In every post of IDK's there is a line of text that says: "Lots of Rocket stuff-worth reading" Click on it and it will take you to a page filled with Lots of Rocket stuff-worth reading!
more than likely u have a newer r3 and u haave bent the tab on the clutch switch so that it is staying on. u can check this by put into neutral and try to start with out pulling clutch. if it starts with out pulling in clutch it is bad.
Opinions are welcome on this thread, but it must be your own. Do not attempt to legitimize your opinion via some other writing, law, teaching, similar event, or source of information.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register. By continuing to use this site, you are consenting to our use of cookies.
