Wasp1
Standard Bore
- Joined
- Aug 12, 2015
- Messages
- 8
- Ride
- Triumphant rocket 3
I don't know if the R3 is a interference motor but it sounds to me like the cam chain broke and valves are bent (or the valves are stuck open due to cam position). Pull the air filter out and put your hand on the pipe. When you crank the motor check to see if you have air pushing back out of the intake pipe. That would be a sure sign you have bent intake valves or valves that are sitting open.
The fact that the motor spins faster than normal suggests to me that it would be likely that you no longer have compression. Just like if you pulled all of the spark plugs out and tried cranking the engine.
Yes i agree with you. I will be sharing this information and helping him monday. will post results of our findings. Thank you for your reply!
