maverick french
Standard Bore
Hello, i'm a young french R3 roadster owner
I've a question about how you check the engine oil level.
I do like the owner book explain, but I have found no oil on the gauje. I have just ride 350 miles since the 500miles check by triumph. So I add oil to have enough oil between mini and max level. I ride about 70 miles, and when I go home I wait about 1,5 hour and when I check the level, It was very high over the maxi level.
I call my local dealer who said to me that he is doing the oil change, they put the mini oil specified when ride 1 miles and go back to immediately check the level.
Can I know how do you check your oil level ?
Is the difference between the engine oil level engine cold and engine run normal ?
Thanks
Thanks
