ratpick
- Joined
- Jul 2, 2007
- Messages
- 18
I may be coming out of left field here, but the symptoms described in the original post at the start of this thread (noise occurs under load, moderate or greater acceleration) and the description of the noise in other posts makes it sound like the "pinging" or "knocking" from detonation.  I don't know how this could occur in a modern engine with computer controlled ignition (should automatically retard timing to fix problem, or to compensate for lower octane fuel).  Maybe this has been previously discussed at length and discounted, but sure sounds like an old fashioned "ping" the way you all describe the problem.  If it is detonation, problem should be worse when engine is warm, and with higher ambient temperatures.  Could try higher octane fuel and/or octane booster to see if it makes a difference.
