R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,514
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
ok i'm back at the computer now so can post some pics.
I run my bench/R&D engine, a (mostly) 06 Classic engine, with a current Roadster GPS, 2013 Roadster ECU and 2010 Roadster harness. It runs perfect and displays all the gears 1-N-2-3-4-5-6 on the tacho LCD.
So i wouldn't see an issue running a 2010 Touring engine with a 2007 07 GPS, harness, ECU.
Some info on GPSeseses (bear with me);
T1190814 "Old" Rockets GPS (2 wire)
T1290642 Original Roadster GPS (3 wire) (used 2010-2013)
T1296589 Update kit for 2010-2013 Roadsters - contains 4 wire GPS under part # T1290666
T1292057 Newest Roadster GPS (4 wire) (used 2013-2018)
Now on the "old" Rockets the GPS pin was sitting in the spool that connects the GPS to the gear selector drum (silver faced yoke below), with a spring behind it to push the pin against the "old" 2 wire GPS;
On Roadsters you don't have that pin and spring setup, the pin is built into the GPS as shown below.
This pin sits into the "yoke" so the selector drum can move the GPS pin around and change the signal the GPS is sending to the ECU.
New vs old
New vs old
