Dennsell
Top Fuel
- Joined
- Jul 5, 2009
- Messages
- 1,860
- Location
- Kawasaki Japan (Perth WA) (GY - UK)
- Ride
- Bonnie T 100, unfortunately not Rocket lll Country
From memory some of the heat shield mounts on the std header are clamp on's I would be checking them all and also make sure one of the heat shields are not a bit close to something and tapping together, but I would be checking the clamps under the heat shields first. I just thought when you used the triumph cat delete did you take the rubber bushes out of the cat and did find they were a bit hardened by the heat, they didn't falll apart did they... You don't have metal to metal under there any where
Good pick Hans yep bush was a bit crappy.
I will have a check under there you could be onto something..
