Does this tune look reasonable? Please Help.
jimbart
CHAPIN
Rocket 3 classic 05
Bike: 05 Classic, stock header and silencer, cat delete, Ramair.
there does not appear to be an exact tune for this setup. Found this one: 20227Map_zwuggle.hex
Rocket III Production silencer Full power Fuel up to E10 Minimum 95 RON (89 RON/MON) fuel
Air filter: KN triple filter installed, without catbox, speed limiter: 250 Km/h, speedometer corrected: -5,
Secondaries slightly open on the 1st, 2nd, and 3rd gear,
Result dynamometer: 145.9 hp at 6100 1/min and 199.8 Nm at 3710 1/min
Idaho Red Rocket 3
Nampa, Idaho
2006 R3 Standard Bagger w/Fairing
Yes. It looks like it is worth a try. Remember to read and copy/save your current tune for safe keeping. You can also tweak this new tune (or any in TuneECU) yourself to your liking before downloading. Open secondaries to 100% all gears all RPM. Lower fan on temp to 96c. Raise speed limiter to 299 KPH, and Adjust Speedo to -8 % if you installed the smaller front tire.
jimbart
CHAPIN
Rocket 3 classic 05
Thank you!
AdBlock Detected
I've Disabled AdBlock
