Thanks so much, I’m on my way to get em 🍻
I just found this thread and have posted previously about these kits.
Image #12 & #5 T3990192 KIT TORSIONAL DAMPER (Notes: Engine number before 336042 - Silver Covers; See Technical News 114)
Image #12 & #5 T3990193 KIT TORSIONAL DAMPER
Image #12 & #5 T3990191 KIT TORSIONAL DAMPER
I have a new old stock one T3990192 for the Silver engine cases here in my shed. There is also a Black case version T3990194. They are identical mechanically with the improved bearings etc band apparently the casing often gets damaged when they fail like your did.
My set came with the new Silver case as well.
Black case: Cover, Output Shaft, Black T1260442
Silver case: COVER O/P SHAFT PAINTED T1260441 (Notes: Up to VIN 242554)
There are 3 covers listed with different part numbers and VIN or engine numbers
17T1260441T3 CVRO/P SHAFTPAINTEx1172.90> Eng No 242554
17T1260442T3 COVER OUTPUT SHAFTx1172.90Roadster Only
17T1260442T3 COVER OUTPUT SHAFTx1172.90Eng No 242555 > 574812
ROCKET III, CLASSIC & ROADSTER 0 - TRANSMISSION DAMPER & DRIVE SHAFT
Triumph ROCKET III, CLASSIC & ROADSTER 0 Transmission Damper & Drive Shaft
RefPart NumberDescription# On Img# Cart$ EachNotes
1T3990194T3 KIT TORSIONAL DAMPEx1874.00> Eng No 336042 - Blk Cvrs; See Technical News 114
1T3990195T3 KIT TORSIONAL DAMPEx1874.00> Eng No 336042 - Slv Cvrs; See Technical News 114
1T1270800**Dead ->REFALEXx11008.40Eng No 336043 >; See Technical News 114
2T1270870T3 CIRCLIPx15.60
3T1270865T3 CAP COLLETx15.40
4T1270860T3 TORSIONAL DAMPER COLx29.50> Eng No 449436
4T1270898T3 COLLETSx29.50Eng No 449437 >
5T3990192T3 KIT TORSIONAL DAMPEx1112.90> Eng No 336042 - Silver Covers; See Technical News 114
5T3990193T3 KIT TORSIONAL DAMPEx1112.90> Eng No 336042 - Black Covers; See Technical News 114
5T3990191T3 KIT TORSIONAL DAMPEx1112.90Eng No 336043 >; See Technical News 114
6T1277777T3 BUSH GEARx155.80
7T1270821T3 GEAR DAMPER 48T Hx1211.30
8T1271992T3 WASHER TORSIONAL DAx118.40
9T1270840T3 FOLLOWER TORSIONALx1129.60
10T1270888T3 SPRING TORSIONAL DAx127.20
11T1270815T3 SHAFT DAMPER THREAx1397.50
12T3990192T3 KIT TORSIONAL DAMPEx1112.90> Eng No 336042 - Silver Covers; See Technical News 114
12T3990193T3 KIT TORSIONAL DAMPEx1112.90> Eng No 336042 - Black Covers; See Technical News 114
12T3990191T3 KIT TORSIONAL DAMPEx1112.90Eng No 336043; See Technical News 114
13T1270886T3 WASHER SPRING DISCx13.50
14T1271111T3 NUT SEAL OUTPUT Mx121.10
15T1270600T3 SHAFT/UNIVERSAL JOINx1646.50Rocket III & Classic
15T1270700T3 SHAFT/UNIVERSAL JOINx1646.50Roadster Only
16T1270500T3 SPRING DRIVE SHAFTx16.30
Greetings friends, I am quite terrified. After repairing and taking care of almost everything, the oil light kept coming up on the highways so we brought down the sump only to find this. does anyone knows what can this be? The bike turns on, rides quite well, gears change is ok, but the oil pressure was low (hence the sump removal) but there is so much debris. Please, help!
It's whats left of a ball bearing
TRIUMPH ROCKET 111 TORSIONAL DAMPNING BEARING DEALER KIT SILVER COVER T3990192
DEALER UPGRADE KIT FOR THE TORSIONAL DAMPER BEARING ROCKET 111. INCLUDES BEARINGS COVER GASKET AND SILVER COVER.
[[[[UPDATE]]]]
The engine is finally down, took everything out and… well… one bearing disintegrated as soon as we touched it, 3 balls fell inside the engine, but we’ll find them later, the other one has still balls in it and quite bad also. Sharing pics now. I just saw in previous answears here that Triumph sends FAG bearings, but the ones here are Korean FAG,. So we went for the NSK Italian made with C3, now it all is left is put it all back together. Hope it goes well.
All your advices came really handy, couldn’t be more grateful to all of you
