Crankcase Vent pickle
I take it you solved all the water and oil leaks from previous threads and bike is ready to hit the road again :)
Water problem is solved. Oil leak was fixed, Had to go check on an issue at work About 10 minutes ago, took Edsel I noticed that the cam cover gasket is pushing out again. 😡
Precisely why I didn't take mine in for the gasket replacement even though it was under warranty. Still took me two times to get it to stop leaking in one place or another.
I never had a issue after I installed it. The factory gasket started to leak after about 15,000 miles. Have installed two or three gaskets since then with no issues. Number four is coming up after I get the transmission fixed.
