DQDude
.040 Over
Got an 2006 R3 and the clutch doesn't want to fully disengage when at a stop. It will clank around until I'm at a stop and sometimes it will want to keep going and I'll have to keep the brakes engaged, sometimes it's like it should be. I noticed both the handle adjuster and lower adjuster are 'll the way out. I removed the cable to compare it to a new one to see if it was stretched or maybe the incorrect cable was installed. Long story short, trying to reinstall the cable and the actuating arm is straight down and I can't pull it up enough to reinstall the cable. Is this normal or is something more sinister lurking under the engine cover? How much uummpphh should be required to move the actuator? Really want to ride tomorrow.
