warp9.9
Pocałuj mnie w dupę
Looks positioned good if you ask me. As for the clicking sound its probably the needle bearings on the lifter shaft two places Piss poor design in my opinion. Or they could have put a little more effort in itWell here are the actuator/spline pics...Warp...great instructions....found it easier to adjust actuator arm by just loosening bracket for adjustor-open end wrench works 10x faster if you loosen these two bolts..Looks like in the position where it was before I worked on it it(I marked it with a permanent marker below the actuator) the spline approximation dot is in the two oclock position and the actuator is hard to tell if approximated as it does not have a dot. HOWEVER....UNLIKE YOUR BIKE WARP...mine does not have an alignment dot so I went off the gap in the Actuator arm...
Any who...Here are the pics and my question for @Warp and @Pedro is should I pull the actuator and reposition it aligned on the spline and does it mean that the is there a universal optimal location for that dot on the spline when the bike is new-say 12 oclock? Warp yours looks to be at about 2 oclock as well..
One last thing I noticed was a faint clicking sound on the clutch cover during the first 1/3 of travel of the actuator arm as the cable pulls it upward....Is is better to adjust the free play above this cliclking tapping sound-or is that normal...Here are the pics....
Thinking clearly and have the concept down now...Just wondering should I realign and readjust the spline to the actuator arm...
Thanks.....Greg![]()
and with the lifter shaft and OEM return spring Peter was referring to
the needle roller do not get much lubrication and do not rotate very much again a little better foresight would have helped
