The Harley Davidson 5 and 3/4" headlight size visor Part #67750-88T fits the Rocket perfectly. Possibly any visor for this size headlight will work just as well, but I can verify the fit of the H-D one. Cost is $11.95 ea. Just remove the Rocket's retainer ring bolt and nut, spread the ring enough to slip the visor underneath, rotate visor to proper position, reinstall bolt/nut and retighten.
I'll try to post pics but have never done so. I do have a digital camera and the Kodak Easyshare program installed in the computer so I'll try to transfer from my files. To describe verbally in the meantime: The visors extend at least 2'' at top center and taper to nearly halfway down each headlight circumference. They are "plain" chrome, meaning no H-D letters or insignias.
Side note to my initial post. Just found that JC Whitney carries the same size visors for exactly half the price of the H-D model. JCW says theirs is a replacement for the H-D part # that I purchased and at only $5.99 ea. Not sure if the chroming is same quality but they are metal, not plastic.
I got my two visors from a local shop, $15.00 for the both of them, took less then 5 minutes to install and they look good, look **** good. I also found Iate less bugs on the way to work this morning then normal, don't know if thats coincidence or if its from the light not going up to head level as quickley.
